  • Replies 89
When i got the car it had a turbosmart boost controller, when off it runs at 5psi, on it runs at 11psi. Whats the stock for a R33 GTST?
Havn't seen any r34 GTRs here in Hobart but have seen one R34GTT pretty sweet.
A few nice 180sx' gettin round now too and a couple of awesome supras.
The '33 runs ~6psi stock. I've had mine at 11psi, however most of the posts I've seen say 12psi is the max you should go on stock turbo.
I used to live in lonny, but moved to Christchurch 2 1/2 years ago. Skyline heaven! :) Got a '97 R33 25t and an '02 NZ New R34 GTt (22,000Kms and still under new car warranty:D). The son-law who lives in Lonny got to drive the GTt when he was over here on holiday. Bugger still likes his HSV's though. Needs to be re-educated.
https://www.sau.com.au/forums/topic/33928-pics/page/5/#findComment-778510
the supra that you are talking about is still the same one. he tried to do a burnout at nut grove beach and ran into a silver R33 with a 400r kit on it. he had the car fixed at tony wells and at the same time came up with 10grand for the kit and decals. also managed to do all this without insurance.
https://www.sau.com.au/forums/topic/33928-pics/page/5/#findComment-780585
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
