Hey Guys,
I was just wondering wat HID should i be using for my HI BEAM
H? ????K ??W (the brighter the better!!)
I currently purchased a V35 not to long ago and it came with HID's already
but where i live has no street lights and alot of kangaroos and rabbits,
so when i turn on the hi beams it does work but u cant even see the difference
as the low beams a just so bright...
Guys i need some help quick before i hit a kangaroo and write off my baby!!!
Had a few too close for comfort encounters already.....
https://www.sau.com.au/forums/topic/339291-hids/
Hi Aaron, there is already a tread about V35 HID.
http://www.skylinesaustralia.com/forums/Hid-s-t338181.html
Have a read and maybe it might help your question. High beams in stock headlights are pretty ok at night. Just have to drive abit careful around that area, I think.
Good luck.
https://www.sau.com.au/forums/topic/339291-hids/#findComment-5480793
That only helps half...or maybe a little of his question.
if 2003-04 models all i know is main lights are H1 fogs are H4. stick with 6000k or less as higher K will emit less light. the high beams works from the H1s so make sure you get a genuine phillips bulb or equivalent so that the main and high beams are both bright.
reason being as before i spent only $200 on my H1 HID from ebay and ending up with 6000k but the high beam was yellow...fail.
https://www.sau.com.au/forums/topic/339291-hids/#findComment-5481021
thanks XTC,
do u think if i added another set of 6000k to the hi beam spot it would make a difference i just need the light to be clearer than now and while u guys a helping me out can i fit 20's on the V35 wit offset front +35 rears +40
thanks guys
https://www.sau.com.au/forums/topic/339291-hids/#findComment-5483137
Adding a 6000 k hi beam wud def make a difference however id prob go around 5000k. As u actually get more light.
With the wheels 20s r fine. Xtc has 20s and also one or 2 oders dat ul c at the cruise have 20s. my 20s are arriving shortly as well. However that offset of +35f and +40R is not wat u shud get IMO . try going more towards the +20-22 mark or bit lower front and rear . Otherwise they wont sit very flush and wont look guud.Also u have to consider the diameter of the wheels. Il explain this to u at the cruise iv made the same mistake as u wid my wheels and have learned by dat mistake :P
https://www.sau.com.au/forums/topic/339291-hids/#findComment-5485137
cheers Steve that would be great i guess im gonna roll around standard for now and when i catch up wit u guys on the cruise u can
give me some advice on size, offsets and other things before i go out and buy the wrong things.
muchly appreciated buddy =)
https://www.sau.com.au/forums/topic/339291-hids/#findComment-5485751
  • 4 weeks later...
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
    • They're not rebuilt Racepace items. They were mint. From memory the were ex display stock that I bought off yahoo and he ran....from memory he barely used the REs when he replaced them with a set of Tein RS If have been stored correctly and not leaked fluid then they will be mint   As an observation the Racebuilt rebuilt Tein RA/RE/RS were a better street/club/track package. Really nice on the street and did good numbers at the track.  I think the factory Teins wont match the Racepace valving on the street but would be in the same window of performance on the track... albeit firmer
    • The one time that Clippy is actually useful!
