I use them for day to day use. Not a bad tyre for street duty at about 180rwkw. Never put them through their paces on the track though.
That said I will most likely be upgrading next time I am in the market to tyres to something a bit more track orientated.
https://www.sau.com.au/forums/topic/339444-toyo-proxes-4/#findComment-5486545
Had them on my old r32 215/35/18 on fronts, and when they got old I put them on the rear and they were ALOT grippyer than brand new 235/35/18 Nankangs I usually had on rear. Not that Nankangs are much of a tyre, but I was very happy with the proxy 4 all the time, exept one delimitated on front due to 2.5 deg neg camber, and shop told me it's my fault for "shitty" camber so no refund. They lasted 10,000km on front
https://www.sau.com.au/forums/topic/339444-toyo-proxes-4/#findComment-5500973
Had a pair of these on the front of the RX when I had it, with Potenzas on the rear. Saw some pretty hard street driving but no track work. Was very happy in what I paid/what I got. Didn't have any dramas but read alot of reviews saying hard work an time (year or so) caused trouble. Eggs, poor response etc...
https://www.sau.com.au/forums/topic/339444-toyo-proxes-4/#findComment-5500988
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
