370Z forged wheels by Enkei 18x8 front and 18x9 rear. Asking for 900
One of the wheel is scrached, the rest are in perfect condition.
Yokohama Advan Sport Tyres, done 12000 kms on them, plenty of thread left. 225/50/18, one tyre slightly damaged but should be fine. Asking $250 for the two. Only normal use, never tracked.
Wheels + 2 Tyres = $ 1100
Apexi AFC Brand new
$450 (SOLD)
GREDDY E MANAGER ULTIMATE BRAND NEW
$650
DO NOT REPLY HERE AS I DO NOT CHECK THIS THREAD ALL THE TIME. SMS TO 0422358259 IF ANYONE INTERESTED IN ANYTHING
ITEMS ARE IN MELBOURNE, HOWEVER COURIER CAN BE ARRANGED.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
