Pro Engines CNC Machined Nissan RB20/25/26/30 Oil Pump Drive Collar
Our Nissan RB Oil Pump Drive Collars (also known as Crank Collars) are precision CNC machined from Chrome Moly barstock. Our collar replaces the narrow oil pump drive originally machined on earlier Nissan R32 RB26DETT crankshafts, as well as all RB20DET, RB25DET, RB30E and RB30ET crankshafts. It can also be used to replace a worn oil pump drive on R32, R33 and R34 RB26DETT crankshafts. Our collar provides full engagement on the inner oil pump gear which greatly reduces the likelihood of oil pump gear breakage in these engines.
Each collar is supplied with detailed instructions and fasteners. Machining is required to fit this collar and therefore it can not be fitted to a crankshaft while still fitted to an engine. We can supply and fit the collar to your crankshaft for AU$350, or AU$550 to chemically clean your crankshaft, supply and fit the collar, check journal sizes, micropolish the crankshaft journals and fit screw in oil gallery plugs.
We have collars in stock ready to ship.
AU$150 each or AU$125 in multiples of 5 or more
this is pro engines.. probably be worth sending your crank and pump over to him! have dealt with him in the past and he is tops... very clued up on 26's
why not collar it?
only requires, machining down and interferance fit/grubscrew
I had a collar but sold it as I've decided to go a different way. I want the snout welded up and machined back to suit my oil pump gears with my specified clearance.
Edited by bubba
What exactly is the question ? Do you want to know if anyone has used Performance Unlimited ? There are plenty of performance workshops around who could provide similar advice.
Have you read the thread on Oil Control ? Do you have oil restrictors etc ?
http://www.skylinesaustralia.com/forums/in...t&p=2039323
Hmmm, I hope this isn't too off topic, but I'm curious about something.
I saw you mentioned in a post a while ago about changing out your lifters and valve springs to push your red line up to ~9000rpm. Where did you get work like this done? I'm quite keen to do this myself as I've swapped out my turbo recently to a 3076, and while lag for these isn't meant to be too bad, it is, at the end of the day a reasonably sized high mount turbo, and I fear that soon I will be lamenting my lack of reponse. How do you rate the change, would you do it again? Is it a good idea?
I saw in the same post you mentioned that you thought most engines would become innefficient at that point, and I'm with you on that, but at which point would you say it becomes unfeasible to rev an rb engine?
Apologies for the essay, but curiosity really has gotten the better of me. And plus I've remembered my password for the first time in weeks and been able to login on something other than my (currently dead) main pc.
Cheers,
Tim
EDIT: Feel free to PM me on the subject to stop this getting even further off topic.
Edited by That_timothy
Take it somewhere where they actually want to work on it? :laugh:
another really good work shop is top racing in carlisle they built my rb30/25 engine its making 550hp at wheels and well over 600 with the shot of nos they listen to what you want and help get it done right the first time
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
