not sure of the exact specs denham
but its got a pretty huge ex wheel and housing on it
on my mates sr20 he runs 26psi but his has a smaller housing and wheel on the back - makes bout 300rwkw
i know that there r other turbos out there that can make that power at lower boost levels - but when ur paying 900 for a brand new t04 what am i to whinge :P
no its chromed its all a bit dirty at the moment and not quite finished but its working out well so far boost response is alot stronger and im having heaps of fun with the external wastegate pipe and pedestrians. the gf rekons it sounds like its goin to hurt someone or sumthing
here she is all bolted back in place.. car goes as well now as it did before on 13psi now only using 9psi so im happy tune up will be soon ill keep you all posted.
Did u manage to hook the 2 springs onto the clips with your xtr thermal blanket?
I am having a bit of a problem getting my to clip on
Hi guys, a lot of people look at the other upgrades (cams, porting, manifold etc), on a turbo car, as a way of increasing the maximum power at one particular rpm point. That's not what I do it for, I actually use these other items to increase the average power over the used rpm range. I also use them to reduce the amount of boost I run to achieve the same maximum power, this increases the responsiveness of the engine as well.
A comparison;
1. I have an RB engine that needs 1.6 bar to achieve 600 bhp with standard cams, ports, lowered compression ratio (thick head gasket) and a combined dump. It has 360 bhp average power (4,000 rpm to 7,500 rpm).
2. The same RB engine that only needs 1.3 bar to achieve 600 bhp with 264 cams, ported, manifolds matched, standard compression ratio and a split dump. It has 440 bhp average power (4,000 rpm to 7,500 rpm).
Some people would say that I wasted my money on the cams, porting, split dump etc since I still only have 600 bhp. I would of course reply yes, but I have a 22% increase in average power, so the car will be substantially faster. Plus the response will be also dramatically improved by the enhanced breathing, with better off boost performance and faster to build boost.
Hope that makes sense.
sure does
ur peak power stays the same but ur power over the rev range to acheive that peak power increases
torque would increase over that rev range to achieve a faster car lower down, resulting in a faster car at higher speeds
correct?
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
