1996 R33 GTST - Series 2
The engine has been rebuilt in the past two months due to new turbo (ATR43). New engine has only done about 2000 kms.
The engine has forged ARIAS pistons, metal head gasket, all brand new belts including timing belt and new water pump.
The new turbo has done around 5000kms.
The car also has the following:
#All four Tein Suspension
#Genuine HKS intercooler
#K&N Pod Filter
#GReddy Profec B-Spec2 Boost Controller
#APEXi Power FC & Hand Controller
#3inch turbo back exhaust which goes into a 3inch high flow cat and that goes into a 3 1/2 inch genuine HKS super dragger
#Turbo smart blow off valve
# ATR43 TURBO
#Remote start/window lift kit
The car is pushing on low boost 200rwkw. On high boost it is pushing 260rwkw. I have the dyno charts for the car.
Things for road worthy - if brought without out one.
#Remove pod filter and replace with standard airbox
#Remove blowoff value and replace with standard
#unplug the hand controller from the power FC
Car in excellant condition. I currently have a company car and have not drive the skyline as much as i would have liked.
about $13,000.00 has been spent on the car in the last 2 years. all work that has been done has reciepts and will provided to buyer.
$17,000.00 ono $15,000.00 with no road worthy cert
Contact: Koosh - 0409 408 990
https://www.sau.com.au/forums/topic/340110-1996-r33-gtst-series-2/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
