It's real easy dude. It's all pretty much the same for any intank direct replacement pump, so just use one of the MANY Bosche guides in the DIY section.
Don't use the instructions for a Bosche pump. If you got the right one, the Walbro should be a model specific factory replacement kit which means no hacking or cutting or cable tying or any of the other crap that you have to do with the Bosch...
But I guess if you got the right one it would also have come with instructions (all for a shade over $100)
Lol, what defines 'the right one'? I used a GSS-342, direct replacement for the factory item. Old harness plugs straight into the new pump, but I replaced the harness anyway to get rid of the old wiring. I used the guide to install a Bosche pump and obviously just did things differently when the guide didn't make sense.
Once you get the pump out and you are looking at the setup, it's very obvious what you have to do. The guide is almost unnecessary but makes things easier if you've never done a fuel pump before.
Sounds like you guys do them all day... lol
Um, I don't even know if I have to take out the fuel tank?? I think I do though. The instructions I got with it were not car specific but they showed how to actually connect the pump. I need the first step like... where the pump actually is! :whistling:
I'll have a look at the bosch guide and I'll give it a go this weekend.
cheers,
Dan
Lol you definitely don't have to take the tank out. You should be able to get at the pump either through the boot or under the back seat, I forget where it is on an R33, one of the other guys will be able to confirm.
It's not a huge job, took me half an hour as a first timer lol
Um...they are a universal pump...no model specific kits
I was reading through the bosch guide and new pipes/hoses were being cut etc. My kit came with some wires, a filter and the actual pump, but no pipes. Can't I just use the original ones there or do I need to go to a shop and get some correct sizing hoses?
My pump is a Walbro GSS 342.
Sounds a lot easier than I thought :)
Pretty straight forward job mate. Take the filter off the bottom, connector off the top, remove the clamps and lift the pump out of the base and remove it from the hose. Installation is just the reverse order. You don't HAVE to replace the hose that joins the pump to the bracket/cradle, but it is recommended to avoid any hassles down the track. Just make sure you get the proper fuel hose as it's dealing with 50+ psi and petrol, garden hose etc WON'T do.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
