anyone has one for sale?
been looking for 1..
heard lots of stuff that the s13 ones dont fit.. (due to sump clearance)
what abt GTR swaybar? would they affect the handling? (mounting points are different)
s13 is the same just go buy em from bursons
ive got an rb engine... i would be perfectly sure if i got sr in mine..
have you tried yourself kris?
there havent been any definite discussions about this one..
ordering it from selbys would be the perfect option, but they went bankrupt right?
The S13 swaybar just touches the sump in a A31.
I belive whiteline took over the selbys line and now are back in action.
so is it actually wearable??
well i went to autobarn and they said they dont make it for a31..
if it touches, it will slam the sump when the swaybar moves does it? if i hit a corner, it will flex for sure
for the ten billionth time, s13 will not fit! neither will anything else. GTR mount points are different (I think) cause of the upper control arm and different knuckle design.
A31 is a unique, one-of shape. I have contacted Fulcrum asking what the f*@# happened to selbys and all they said was they will be producing sway bars using all teh old selbys gear and info but they haven't started producing the sway bars yet. As far as I understand they moved into the old selbys shop in Sydney. I found a web page the other week claiming they have the selbys family working for them, producing custom sway bars. I'll try and find it again.
Edited by RBceffy25
Mine had a S13 bar in it, compared to a stock ceff swaybar, the part where it bends around the sump area is a few inchs shorter than A31, hence the s13 just touching the sump.
I would be still using it if it didnt foul my 6.5 ltr sump, the stock ceff swaybar also hits my sump :)
Kris has a S13 swaybar in his A31, post so pics up for us man.
Toffy runs a 32 GTR front swaybar with no hassles?
Edited by works 510
s13 will fit the suspension geometry and it will definitely work well with SR20 engine...
currntly stuck wit the rb20 but if i use swaybars exactly for a31 i would still be able to use it for the sr20
so selby is still stuck with the finances...
id take any custom made ones.. i wonder what huddy put on his ceffy
well fu@# me....... I dont know how many of these exact threads i have read about ceffy swaybars but no one ever has straight answers.....
until now :P
Pics please?
Yes of course it would fit perfectly with an SR... I think thats the whole point we are all trying to make
If any one is interested, all I need Is a standard front sway bar and have it sent to a guy I found to use as a template/sample. Then we can all have actual heavy duty, adjustable 27mm A31 Cefiro swaybars!:P
If any one is interested, all I need Is a standard front sway bar and have it sent to a guy I found to use as a template/sample. Then we can all have actual heavy duty, adjustable 27mm A31 Cefiro swaybars!:)
So no-one has one?
C'mon people! Real, actual A31 front sway bar!
selbies make them i had one ordered, it was delivered about a fortnight ago but im splitting cats car up. I just sold it over the weekend.
I would be still using it if it didnt foul my 6.5 ltr sump, the stock ceff swaybar also hits my sump :P
yep , fits perfect , all you have to do is bolt it to the lca instead of the strut (let the connecting arm hang down instead of up) . simple , so i'm assuming r32/s13 are very similar and should fit , when i start stripping my car down i will take pics and post up a thread instead of spamming lol
do you have the contact number? i saw fulcrum website they said they took selbys and puts them back to life.. but then i emailed them to order it n then nothing happens :s
called them and they said they gonna call me back... dont hear shit from them since then..
if you have any more custom made front sway bar, id be happy to be your trash can :ermm:
oh and is the front tension bar important as well? i saw kris had it fitted on his..
just wanna know if its worth my 150 bucks
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
