Have some A050's in Medium compound for sale. They are 255/40/17 all round.
They have done two track days, one at Eastern Creek, the other at Wakefield.
Current wear is:
2x80%
1x90%
1x60%
Looking for $1000 for the 4 of them which I think is dirt cheap since they are 2k new.
Contact: via PM
James
https://www.sau.com.au/forums/topic/340545-advan-a050s-2554017-x-4/
Here you are. (can't be bothered logging out from Matts account)
As you know, A050's just like most R comps have 4.8mm tread when they are brand new so when they hit the indicators they are only just under 50%.
http://picasaweb.google.com/lh/photo/od4aJ...feat=directlink
http://picasaweb.google.com/lh/photo/EaP5i...feat=directlink
http://picasaweb.google.com/lh/photo/YqAJh...feat=directlink
http://picasaweb.google.com/lh/photo/YCOqp...feat=directlink
http://picasaweb.google.com/lh/photo/_vgtl...feat=directlink
http://picasaweb.google.com/lh/photo/4Hj3g...feat=directlink
Edited by boxheadmr
  • 4 weeks later...
  • 3 weeks later...
Come on guys... surely you want to grab yourself a christmas present to make you go faster in the new year. I can't believe I can't sell them at this price they are dirt cheap!
Price reduced to 800 not negotiable.
  • 3 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
