I have a HKS GT-RS turbo in excellent condition. There is no shaftplay and spins freely. It has just been removed from the Stagea due to a small upgrade (HKS 2835 ProS). It is a direct bolt on turbo kit that fits the factory dump both location and flange. It also connects to the factory rubber intake pipe. Included is all oil and water lines that are required.
This turbo is probably the most responsive turbo available on market for an RB25 but would also be perfect for and RB20 due to its early spool and excellent midrange. As a comparison the new turbo on the Stagea is noticeably less responsive in on/off/on throttle situations (and the 2835 ProS is no slug). They are listed as a 400ps turbo by HKS and it is reasonable to expect 240-260rwkw.
If you are after a fantastic streetable turbo and don't want to pay the current price from Nengun ($2753 plus delivery) this will suit you.
Price for the turbo and lines is $1700.
The dump pipe shown is also available for $100 if required.
I am located in the Hills District in Sydney.
i can come to sydney next weekend and buy it off you. cash is fine yea?
i cant pm yet so just shoot me an email to [email protected] with the details
Thanks Warlord and crzy. It is a great streetable turbo.
Louie B, I was running 480cc Nismo injectors on the stagea.
Willing to post for interstaters and will be packed very carefully before it gets sent.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
