a few parts left from a 34gtt i have recently stripped,
may consider swaps i need some stuff for my s13 (rb25 gearbox, clutch fan etc)
prices are negotiable but no stupid offers.
-neo engine cover (pics available we all know what it looks like) $10
-small carbon canister (has a couple vacum lines going into it i assume its a carbon canister) $10
-r34gtt drivers and passenger rear quarter panels, (both have been cut off of a damaged car. there is plenty of steel left on them around the panel joins. any beater should be able to unstitch to attach to a damaged car) $100 each
-r34 rb25 air con compressor and tensioner pulley (unchecked ive never used it, looks fine?) $50
-r34 gtt 2 1/2 inch exhaust, caqt back, includes nismo muffler with a electronic silencer valve (have pics) $50
- r34 gtt drivers a pillar trim good condition, few scratches near where it meets the glass good if yours has holes drilled in it $10
-r34 gtt drivers and passenger rear trims one has a coupke of small marks in the plastic $ 20 each
-r34 gtt hicas rack, removed for fitting lock bar $50
- r32 gtst hicas rack and some lines removed same reason as abouve $ 50
-r34 gtt fuel tank its useless to me $20 without pump or $50 with pump
-r34 gtt parcel sheft, has child safety restraint holes drilled in speaker grills $10
-r34 gtt tripple gauge cluster, the one that sits abouve the centre of teh dash, average condition could use a clean. no gauges $10
-r34 gtt child safety mount braces left and right $10 pair perfect for compliance
-r34 gtt rear window wiper motor $ 10
-r34 gtt steering column, with key, key seems stuck in barrell, $20
-r34 gtt wiper stalksand brackets that bolt to the steering colum $ 20
-r34 gtt drivers floor kick panel witha little peep hole thing (fuses?) $10
-r34 gtt bonnet cable $10
-r34 gtt fuel cap and boot opening cable $10
-r33 standard alloy wheels, good tyres, easily legal tread on all 4 $200 ono
thats all i can think off of the top of my head prices are negotiable within reason of course
will post some items pickup preffered from the barossa valley in south australia.
cheers jamie
https://www.sau.com.au/forums/topic/341009-r34-gtt-parts/
Hey there, this might seem like a weird thing to be after but i cant track one down anywhere, i need the right reverse light lens, you know the ones on either side of the number plates, i bought the car with it missing and i just hate looking at it, if you have both ill buy both to make it abit more worth your time, im desperate to get one so it would be great if you have them still..
Cheers,
Elle :-)
Oh i just thought of something else, i dont know how to explain it, umm you know the lever you use to recline the seat, well the one on the drivers seat in my car is missing the plastic bit that fits over the actuall short metal bit which makes it so difficult to adjust the seat back cause you dont have the big plastic bit to just grab so you've gotta dig ya fingers down to grab the little bit of the metal, it would be awesome if you had one, sorry i know that was probably a confusing explaination of what i was tryin to say.. :-D
Edited by elle
https://www.sau.com.au/forums/topic/341009-r34-gtt-parts/#findComment-5514768
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
