ok this is going to sound stupid and very fast and the furious. but since insurance is not in my favour rice at the moment is the way to go.
im looking at getting a nitrous bottle for display at car shows. but his has made me decide why dont i do something with it.
everyone knows about the purging of the r34 at the beginging of 2fast2furious. thats what im after. i realise i probably dont need a nitrous filled bottle to get this effect and in the end it probably wont be. but how would the system be setup to purge ie parts, lines switchs and crap. any ideas.
~sits back and prepares for the payouts~
https://www.sau.com.au/forums/topic/34105-nitrous-purging/
  • Replies 114
Theres an article on the ZEX system in a magazine.. not sure if its Zoom or HPI
but its one of them
u can get an extra purge system with it for like another $100, it allows instant fresh NOS allowing better times.. not just rice look
it sprays out basically where ever u put it
in this one they put it coming out of the windscreen where the wipers were
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-683856
Instead of just wasting it you could get an Ntercooler kit from Nitrous Express. Basically its that ring you see in front of the intercooler on the R34 on 2f2f. It sprays NOS (or whatever else you have in the bottle) on the intercooler and as the pressurised gas is released and hits ambient temperature air it has almost a "freezing" effect so will dramatically drop the temperature of your intercooler core, and as such, drop inlet temps.
Then also on this system, you could have a purge valve hooked up so you could rice it up when you want too, but also have it in there doing something useful. Also instead of filling the bottle with NOS, just use CO2 as its a hell of a lot cheaper and has the same effect on the intercooler.
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684036
if u want that effect. you will need to buy two purge N.O.S kits from a N.O.S dealer.
very simple to install. everything comes with the kits i belive.
used to run a single one on my old car (but i did actully have a nos kit)
rember a tank of nos is 80$ and depending on how much u will purge it out it will be wasting money.
still if i saw it on the STREET i would not race you.
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684046
Champion!!!! exactly what i'm after... i remember seeing one of these from a link on one of the forums somewhere...
How much are they?... where (IN AUS) can they be purchased....
Atleast these perform a duty.... lol... not TOTAL rice :)
Also, where do you get CO2 refills?
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684128
Aww come on, what about the electronic B.O.V. for N/A motors? Surely that's gotta come in at least a close second?
Nah... those Plastic intercooler kits for that...
'All important turbo look'
they would HAVE to be there too :headspin:
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684668
not if we stand close enough to the purge :P
The stuff the dentist's use is alot more pure than the industrial NOS.
I used to work at a lab and every 2 days the BOC gases truck used to change a stack of Gas bottles and 1 of them being a big ass bottle of NOS. We used to use NOS for cleaning the precision instruments. I always wanted to pinch 1 of the NOS bottles but it was to big to fit in my Cortina. :)
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684680
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
