When I first went to a drag meet and saw NOS equipped cars purging out under the windscreen I used to think it was just water to clean there windscreen before a run thinking they couldnt have wipers coz they would break off at high speeds. LOL
  • Replies 114
The low grade nitrous used in NOS systems or commercial applications has sulphur in it to prevent misuse. The medical grade found at the dentists, hospitals etc. doesn't have that element - but I think you need a license to purchase the good stuff.
purging is all i want. and i know it will be rice. very very rice but that what im after. for now anyway.
a non flmable gas on a home made system? what type of parts would you need..?
electronic valve and a heap of pipe work maybe
since the install of nitorus is not going to be done properly anyway why not use a cheap alternative like carbon dioxide.
Money is no object to ricers chasing the dream of making their cars look fast hs.gif
Nitrous Oxide is not flammable on its own, however once it is mixed with a hydrocarbon like fuel and an ignition source then you have an explosion on your hands. It works in a similar fashion to that of oxygen in a fire, in that it is the oxidizing agent needed to perpetuate the reaction. It produces a more intense heat and hence more energy is liberated per unit fuel.
hahah, it would be a bad to spray c02 into your intercooler, not only will your car run lean but it woudlnt be as flamable, you would best off putting oxygen into you airflow meter, that would feed into your turbo, effictivly cooling your inlet turbine, and allowing the AFM to read the oxygen that is passed into your engine.
as far as wanting your car to purge, jsut buy nos for gods sake and get a propper purging system.
also purple is ment to be a poofter colour. :)
Ummm excuse me what??!?!?!?
Merli, this thread HAS to win an award of some kind doesn't it?
Adrian
2rismo: Gotta get me one of those lights with the purge kit... the blue will match my ricie blue underglow kit... :wave:
MotoX: ummm, yeah... we where talking about ONTO the intercooler man....
Browny: lol... funny how the obvious things never come to mind isn't it, thanks mate... didn't even register in my head... lol
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
