  • Replies 46
Because I pressed the wrong button! Sorry about that.
$20 for the stone guard and I wouldn't mind some of the climate control lights if you will split. I live in Hornsby and can collect.
I have the stone guard, $20 is fine, also have the climate control module $50 for that. Just call me on 0418 672 182 if your interested.
Thanks
Hows the frotn bar? Also do you have the top dash vent on the drivers side right next to the pillar
Sorry the rear front bar was smashed and the interior has been sold.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
