Selling my 33 Gtr. Condition of body is O.k. There is pain fade on the roof and wing as well as some hail dings on bonnet and roof. Front bumper is heavily chipped and rust in spots. So it could do with a respray but I don't mind as I have had it for 6 years and just enjoy driving it.
Mechanically. It's very reliable, and has been running 340kw 1.5bar at the wheels for the last 4 years. I recently removed the 4" cannon and replaced it with a big muffler and cat and now it's boost is restricted to 1.2bar but unsure of what power it's producing at that boost. But it is nice and quiet now and I enjoy driving it much more as there was way too much drone.
It has all the mods internally and externally to support those numbers easy.
18" driftek rims.
8 months NSW registration.
$12000
Bowlgowah/ Sydney
0431540388
https://www.sau.com.au/forums/topic/342034-95-r33-gtr/
I'm out of town at the moment sorry. I have put it up for sale here about 6 months ago with a pic but can't find it. Be back in syd tomorrow and will get more up.
Mods list
Brand new HD exceedy clutch.
Trust front mount
Trust oil cooler/relocated kit
Trust fuel rail
Trust pod filters
Sard injectors
Power enterprise turbo's Response Series (N1 equivalent)
Power enterprise dumps
Arias pistons
Acl race bearings.
Trust metal gasket
Reconditioned head
Greddy boost controller
Turbo timer
RDA rotors front and back 6 months old
Bendix ultimate pads front and back 6 months old.
And as luck may have it I have just lost my phone. So i can only receive communication through here for now. Sorry
Selling cause I have found my new car so the cash will help fund that.
Cheers.
https://www.sau.com.au/forums/topic/342034-95-r33-gtr/#findComment-5518580
The Km's on the dash read 125 000. The rebuild of the motor was done at 65 000 klm's.
6 Months ago I got the Mod bug again and pulled the motor down with plans on doing a Rb30/26, but now I would just prefer to buy a 34 GTR.
So while the motor was out I got new Acl race bearings put in before they put it back together and back in the car, the rest of the motor got a clean bill of health, have documentation/receipts for everything done to motor.
Will post pics up tomorrow, as I have just got back to sydney and it's bit dark for anything decent.
https://www.sau.com.au/forums/topic/342034-95-r33-gtr/#findComment-5520453
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
