Hey guys,
Just wanting to find out if there is actually any difference in the lockbars
Reason i ask is that i can get a good jap brand one, but its to suit a R32 and not a R34... i know the 34 only has the bar, where as the 32 has a bit more to do like hydrolics...and the bar
If anyone could let me know it would be greatly appreciated!
Cheers Mick
https://www.sau.com.au/forums/topic/342458-lockbars/
