Nissan 200sx s14 s1 $13,000 with r33 gtr rims not the one's in the pic
*Twin thermo fans
*Exedy heavy duty clutch and fly wheel
*Blitz pod filter
*s15 motor (110,000 kms)
*s15 6 speed
*s15 suspension
*s15 rear end diff, hubs axles ect.
Interior:
*Pioneer head unit
*6 inch pioneer speakers
*Velo race seat
*Fire extinguisher
Exterior:
*Full JDM Aero Kit
*Amazon Green(Standard)
*Rolled Front Guards
*Pumped/Lipped Rear Guards
*Removed Standard Wing
*Origin Front Clear Indicators
*Commo Spec Clear Guard Indicators
im in tasmania. cheers dave
https://www.sau.com.au/forums/topic/342465-green-s14/
*Twin thermo fans
*Blitz pod filter
*s15 6 speed
*s15 suspension
Interior:
*Pioneer head unit
*Velo race seat
*Fire extinguisher
*r33 gtr rims not the rims in the pic
Exterior:
*Full JDM Aero Kit
https://www.sau.com.au/forums/topic/342465-green-s14/#findComment-5525087
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
