location? and what colour is the car? might grab the passenger side door
sorry mate its gone im in geelong but my mate has a green one could find out if he wants to sell it
Dude u might wanna change ur topic title to R34 from R33...
i would if i knew how lol i dont realy post much and am kinda dumb when it comes to computers
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
