hey all as stated im looking at selling my pride and joy ive only owned the car for 4 months and the only reason im selling it is i need the cash for a house deposit so there will be (NO SWAPS SO DONT ASK THANKS) the engine was built in japan bout 6 months ago and i just got a compression test done and reading between 154 and 156 between all 6 pistons if u wish to have alook at the car ur more then welcome but no time wasters or tyre kickers please this car has had approx $50000 spent on it and it is very quick its been tuned to run on 1.2 bar atm moment but was tuned in japan to run 1.6 bar pumping out 710hp im asking $37000 ono
contact me on here or email me please [email protected] cheers
GTR SPECS
CYLINDER BLOCK NISSAN STD.
CRANK SHAFT " (FULL BALANCED)
PISTON " (86.0Φ)
CON-ROD "
HEAD GASKET TOMEI METAL (1.2mm)
INTAKE-EX.MANI GASKET "
CAM PULLEY " (ADJUSTABLE)
CAM SHAFT IN. APEX V-MAX (270° 9.15mm)
" EX. " (280° 9.15mm)
VALVE NISSAN STD.
VALVE SPRING " (REV.LIMIT 8300rpm)
TURBINE TRUST T88-34D 15cm
EX.MANI " ALL STAINLESS
WASTEGATE " TYPE-C HIGH FLOW
MUFFLER ORIGINAL TITAN 100Φ
CLUTH EXEDY METAL TRIPLE(TYPE Drag)
MISSION GEAR OS-GIKEN 1-2-3 CROSS RATIO
FRONT LSD. CUSCO 4-PINION 1WAY
REAR LSD. NISSAN STD. 4-PINION 2WAY
FINAL GEAR RATIO 4.1
ECU APEX POWER-FC D-JETRO
FUEL INJECTOR DENSO 720cc/min LOW RESIST
FUEL PUMP DENSO 280L/min ×3(DIRECT DRIVE)
FUEL DELIVERY PIPE TRUST 11.0Φ
FUEL REGULATOR SARD TYPE-J HIGH FLOW
FUEL CORRECTOR TANK " (5L)
MAX BOOST 1.6 K
MAX HORSE POWER 710HP
https://www.sau.com.au/forums/topic/342912-for-sale-1-33-gtr-v-spec/
also i forgot to say that i recently put peronalised plates on witch say (BUS73D) or busted
i did a fuel test a few weeks ago and im not trying to deter any1 it uses 17 litres per 100km on highway not sure in city driving but i put about 40 litres in a week for work and it gets me 100km approx like i said its not to deter any 1 just been upfront bout it all in all its loud when it idles it shakes the car from side to side from been lumpy as will try and post a vid cheers
ok here its is the vid of it the day i bought it hope u guys like
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=faaa3fgfzO8?fs=1&hl=en_US"></param><param'>http://www.youtube.com/watch?v=faaa3fgfzO8?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=faaa3fgfzO8?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
cheers mate it is a beast and goes like 1 to it has a t88-34 d turbo on it so boost dont come on till 5000 rpm but once that happans hold onto ur socks boy lol
i know dude... no one is spending cash on these thing.. the ass has really dropped out of them unfortunatley. my mate just sold his.. not as much work as yours.. was extremely neat tidy.. real good package.. for 22k!
i went to croydon motorsport yesterday and spok with jim and he said the turbo that is on my car should be running higher boost than what it is for the work my motor has had done,,,,,its only running 21psi he gunna tune it to 32psi on c16 fuel (approx 550kw atw yeeeeeehawwwwwww)
ok all im off to the mines in western australia next friday i need the car gone please .......make an offer over $30000 and c were we end up cant stress enough i want it gone other wise it will be sitting in the shed gathering dust not getting drivin and need cash for deposit on house.... cheers
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
