Need to get rid of the engine/box/loom/computer now in good condition, ran well, 112,000 k's. . . . $1000 firm. At least 2g at wreckers, more likely 2.5g. Cheap people!!
Ill have a look for regarding the cat, how do you tell the difference though??
Update on sold items:
Ashtray
Steering wheel and drivers side airbag
Brake booster and master cylinder
Rear disc rotors
Foglights and switch
Rear door actuators
Passenger front door actuator
Interior Carpet
A pillar Trims
Headunit surround
Centre dash air vents
Weathershields
Fog lights
LHS tail light (RHS still available)
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Rear LH quarter panel (cut out - bit of a job)
Upper centre console plastic
Climate Control unit
Handbrake Assembly
Tweeters
Drivers sun visor
Rear wiper arm and motor
Centre rear seat belt
Rear bumper
Child restraint anchor points
Ashtray
Rear disc rotors
Rear door actuators
Interior Carpet
A pillar Trims
Headunit surround
Weathershields
Fog lights
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Handbrake Assembly
Tweeters
Drivers sun visor
Rear bumper
Rear parcel shelf trim
Power steering high pressure hose
Ashtray
Rear disc rotors
Rear door actuators
Interior Carpet
A pillar Trims
Headunit surround
Weathershields
Fog lights
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Handbrake Assembly
Tweeters
Drivers sun visor
Rear bumper
Engine including starter, power steering pump, aircon compressor and alternator
Auto gearbox
Engine wiring harness
Engine computer
Feel free to make offers on anything else thats not listed as being sold. Thanks
Ashtray
Rear disc rotors
Rear door actuators
Interior Carpet
A pillar Trims
Headunit surround
Weathershields
Fog lights
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Handbrake Assembly
Tweeters
Drivers sun visor
Rear bumper
Auto gearbox
Engine computer
Driver Seat
Passenger seat
Wiper arms
How much for the exhaust and is it stock??? and also how much for the stock wheels, how much tread have the tyres got?
cheers
Ashtray
Rear disc rotors
Rear door actuators
Interior Carpet
A pillar Trims
Headunit surround
Weathershields
Fog lights
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Handbrake Assembly
Tweeters
Drivers sun visor
Wanna get rid of the rest of the stuff guys, no takers on the head unit?? 100 bucks for the unit, only a couple of months old.
Edited by Midnight34
Ashtray
Rear disc rotors
Rear door actuators
Interior Carpet
A pillar Trims
Headunit surround
Weathershields
Fog lights
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Handbrake Assembly
Tweeters
Drivers sun visor
Rear bumper
Wheels
Air flow meter
Exhaust system
Offering the head unit for $80 bucks. has remote and not used hardly at all, last years model.
Ashtray
Rear disc rotors
Rear door actuators
Interior Carpet
A pillar Trims
Headunit surround
Weathershields
Fog lights
Bootlid
Front LH guard
Front RH guard
Exterior Mirrors
Gauge cluster
Handbrake Assembly
Tweeters
Drivers sun visor
Rear bumper
Wheels
Air flow meter
Exhaust system
Diff
Driveshafts
Headunit
Full set of factory mats still available for $60 in good nick :)
  • 4 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
