Ill hold the unsurmountable use of profanity in this post and put it simply, I got yellowed, for the following parts…. Any help and advice on finding, borrowing parts, or just intelligent ways of going around these things would be greatly accepted.
- No rubber mats on pedals.
- No tyre placard?
- No airbag on steering wheel.
- Need a new ca18det radiator mount.
- All brakes "worn". Don't know what the f**k that numpty knows about brakes, but ill be upgrading anyway, so hit me if your selling some,
- Seatbelts "worn".
- "Front" mount turbo, LMAO.
- Pod Filter. Are they not allowed either?
Any help welcomed, thanks everyone…..
https://www.sau.com.au/forums/topic/343490-yellowed-silvia/
Don't have any parts for you but my skyline got yellowed for the brakes not working. The way he checked was put his hand on the disc and told me its cold so they arn't working. He also asked me if i felt the brakes not working, I said no and he carried on that it's probably because im not a mechanic. I am a fitter and turner and im pretty sure there is nothing wrong with my brakes but what are you going to do about it. I am just going to machine the brakes and get new pads for it, far easier then fighting it.
https://www.sau.com.au/forums/topic/343490-yellowed-silvia/#findComment-5538634
what do you actually have that was classed as "front mount turbo"? is it an intercooler? depends on whether you had to cut the front reo to get it in as to whether it's illegal or not. also depends on your states rules regarding intercoolers as well.
pod filter, again depends on your states regulations. i only know qld's where they are fine as long as they are secured with a bracket. some states though don't allow both a pod and an intercooler. you can either have 1 or the other.
no rubbers on the pedals is one not many people know about. just go to a wreckers and get the pads off a random car and see if they fit.
the no airbag one should only apply if the car was fitted with an airbag standard. if it wasn't then they can't get you for it, however, if you have an aftermarket wheel they can get you for being too small.
tyre placard, well i'm not sure how you'll get that one sorted. if they normally have them inside the glovebox then just get a new glovebox.
brakes, well depends on whether your pads were really worn, or the rotors were.
seat belts, bit hard to say about that one. are they frayed at all?
radiator mount, well again, just get a new one.
long story short though, most of the stuff you got done for is your own fault and you are actually in the wrong.
https://www.sau.com.au/forums/topic/343490-yellowed-silvia/#findComment-5538649
- No tyre placard?
I'm sure you have friends with Silvias. Look at their tyre placard - if they have one it will be a sticker stuck onto the driver's side door jamb under the door striker... Now go use your fav publishing program to copy it and print it on sticker paper. This is what I did
- Seatbelts "worn".
frayed? If it's not frayed but just not retracting properly then chuck the seat belt assy in a bucket of detergent water overnight. If frayed, order some new Klippan ones from an auto store. Silvia S13 front driver = K6303 + K4425, front passenger = K6304 + K4425
FMIC maybe? Can't be cutting reo bars
Not sure on this... I got away with it as mine is hidden under the nose panel from above and by an undertray from below...
https://www.sau.com.au/forums/topic/343490-yellowed-silvia/#findComment-5541468
How the fark can they tell if the brakes are worn w/out taking the wheel off?
by looking through the spokes in the wheel and seeing how much meat is left on the pad. and then if you feel the rotor for a wear lip you can tell how worn the rotors are (or at least how worn since they were last machined)
https://www.sau.com.au/forums/topic/343490-yellowed-silvia/#findComment-5541833
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
