As stated above, I have a set of Front Pipes for a R33 GTR. - May fit R32 & R34. Not sure.
They are made by JJR. (Just Jap Racing).
Purchased 6 months ago for $300 + postage.
Selling for $200.00
They are Dual 60mm Pipes & a 76mm Main Outlet.
They also have 12 Months warranty. (6 Months remaining)
Front pipes have been Painted Black with VHT heat paint.
Front pipes are located in Melbourne western suburbs.
I can be contacted on 0421205751.
As I no longer Own a GTR, I'm hardly on this site.
SO please use the number provided in order to contact me if interested. - Try not to PM as most likely you will not get a reply for weeks.
thanks
Edited by Royalflush
https://www.sau.com.au/forums/topic/343539-gtr-stainless-front-pipes-melb/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
