I just picked up my R32 GTR from its quarantine inspection and when I revved the vehicle to about 6K rpm's suddenly heaps of thick smoke began pouring from the exhaust. It seems that the smoke was only generated when the car was in gear as it would thin out when in neutral.
When I stopped the vehicle it wouldn't start again. The engine would turn over but not fire up.
Has anyone experienced similar problems? I have been told it might be a blown oil seal in the turbo.
Any help would be appreciated
https://www.sau.com.au/forums/topic/34356-thick-smoke-pouring-from-exhaust/
eek.. do a compression check, or get a mechanic to do one. That should fairly quickly tell you if its engine related, or turbo related.
To see if its a turbo oil seal, pull off your intercooler piping and check for masses of oil in there.
no - signs aren't good.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
