Alrighty, i can't find any threads that cover this. I got a 86 GXE R31, doesn't have cruise control, obviously, the TI's do however.
How easy is it to put cruise control in my car, if possible, and what are the costs involved? How much for me to do it or how much for my mechanic to do it roughly. And would i be able to use a standard one or would i have to go aftermarket?
Cheers
https://www.sau.com.au/forums/topic/343592-r31-cruise-control/
because then you can simply just walk into any auto parts store and buy a kit. don't have to worry about buying all the little parts that you may require for the stock unit. the aftermarket kits are designed to fit pretty much any car. i've had 2 cars with aftermarket kits, and they both worked reasonably well. one better than the other though.
how much did you pay for your better one installed?
Are they easy to remove?
both were in the car when i bought it. only difference between the 2 was how smooth they engaged when activated them. one was much jerkier than the other and would give a burst of acceleration for a second when you activated it. having a highflowed throttle body though didn't help the situation, but even before that it wasn't as smooth. the actual functioning of each was pretty much the same though. i'm going to get one for the current car some time when i could be bothered (and have the money). also might try and make up a light on the dash for it too
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
