Item Summary: 1999 JDM S15 200SX 6 Speed Spec - R Front Mount, Twin Pipes, Volk Rims
Condition: Used
Reason for Selling: Buying New Navara
Asking Price: 18900 ono
Delivery Methods: PickUp
Contact Info: Brad 0450 194 170
Extra Information:
hey all,
Havent had the S15 Long but my job requires me to have a ute that i can tow with.
Details of car:
1999 Jap spec S15
JDM Spec SR20 Black Top
Factory silver/grey paint
6 speed stock manual transmission,
Standard LSD, Very tight...
This car has a genuine 160,085 kms.
The car is reliable, with a strong engine which has been serviced every 5,000 kms with Quality Synthetic oils. Has had new oil filter, spark plugs and fresh coolant, just had a wheel and coilover alighnment,
Encumbered Free vehicle. You can check at https://online.revs.nsw.gov.au/revs/Public.htm
VIN: 6U900000S15010245
Engine Number: SR20452638B
Rego: 594MVG
Interior:
Standard black cloth interior with
R32 GTR seats, tear on drivers support (not plated yet)
Greddy turbo timer
Calibre Boost gauge in standard stock A pillar pod
Turbosmart 2 stage boost controler.
Drift hand e-brake button
nizmo gear knob, no dildo.
Standard s15 Airbag Wheel
Full electric windows, mirrors, central locking...
Full electric climate control with very cold A/C
Dark Tinted windows with top front windscreen strip tinted aswell
Extra wide JDM rear vision mirror.
Silvia Autech Version interior floor mat set.
Exterior
Almost New RAYS ENGINEERING 18inch GT-C face 2 high polished finish Wheels, details are:
Volk Racing GT-C, 18 x 9 + 31 (fronts) with NEW!! Federal 595 Evo street slicks
Volk Racing GT-C, 18 x 10 +22 (rears) with Federal 595ss's
Rays wheel nuts and Nizmo caps
15mm bolt on spacers (front)
Aftermarket Nismo type Monkey LED rear lights
Side Skirts (JDM silvia)
Nismo rear pods
no rear spoiler
Red detailed brake calipers front and rear
Clear front indicators
Aftermarket Zenon 6000K HID's low beam
Engine/Exhaust/engine Bay add-ons etc
X force aftermarket split dump pipe
Full 3" JAZMA exhaust with high flow cat and muffler with 3inch angled twinpipes
Blitz pod filter
Standard JDM Spec T28bb turbo
Turbosmart 2 stage boost control, with low set on 7psi, and high set on 12psi)
Cooling Pro Intercooler, intercooler pipes, & hoses
BOV (HKS SSQ copy)
Tomei Rocker Arm Stoppers
Odyssey dry cell battery
GReddy oil filler cap
Cooling Pro Radiator cap
Brand New Extra Heavy Duty Clutch installed on the weekend from Direct Clutch Services also a Brand New OS Geiken Flywheel
Suspension/Handling
NEW! GREDDY Type-S 32 way damper adjustable coilovers in the rear @8kg.
NEW! GREDDY Type-S 32 way damper adjustable coilovers in the front @10kg
just Fitted They are over $2000 new, These coilovers are top of the range!!! By far the best I have used and reccomended by everyone!!!
ISC adjustable rear camber arms
ISC adjustable castor rods
Aftermarket Rear Strut Top brace, and Std boot floor brace
Aftermarket Front Strut Top brace
Audio System
Kicker component splits up front
Pioneer mid range rears
kicker 300w amp
kicker ES 12" sub, boxed.
Poineer headunit
Security
Mongoose M80 alarm and immobilizer with motion detectors in car.
Automatic Locking and window wind up actuator also when alarm is activated(can also be turned off by switch)
Roof has an unusual dent looks like somone has jumped on the roof and its been popped out. Not really that noticeable... It's no show car, scratches here and there.
Pics Below
Uploaded with ImageShack.us
http://img213.imageshack.us/i/img07461.jpg/
http://img17.imageshack.us/i/img07431i.jpg/
http://img812.imageshack.us/i/img07441.jpg/
http://img26.imageshack.us/i/img07451.jpg/
Edited by MYP16
https://www.sau.com.au/forums/topic/343959-1999-jdm-s15-200sx-6-speed-spec-r/
  • 6 months later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
