Hi People,
All items located in Sydney - Epping.
Post ok if buyer organises OR can deliver certain items
Contact any time -
PM on here
Cris - 0403491735 Call or sms
Adrian - 0413208919 Call or sms
Photos on request - inspection welcome any time!
WE NEED ALL OF THIS GONE! NO REASONABLE OFFER REFUSED!!!
Willing to trade for items of interest including (cash either way depending on item and condition) -
Front facing RB25DET intake manifold.
Bride Seat + Rails.
R32 Half/Full Cage.
Wheels of interest.
Genuine GTR front bar cover.
RB25DE SII
Complete engine in great running cond.
Came off a Stagea.
Comes with manual R33 ser2 ECU.
Comes with front AWD diff - You can change to RWD very easily and sell the FWD diff.
Never skipped a beat, ever.
Only top fluids used.
Regularly serviced.
Did a compression test before removed and showed to be very healthy engine.
$700 ONO
RB20DET Head
Complete head, has a small weld on one side so selling as is for cams, cam gears etc
Must go, need the space!!!!
$150 ONO
R32 GTS4 Front Diff
Comes complete with sump assembly and diff housing.
4:3 ratio!! Perfect for lowering your GTR diff ratio
Working perfect when removed from car.
Barely used as car has been often run in RWD mode.
$500 ONO – MUST GO!!
RB25DET Block
Needs oversized pistons - been bored out
Bores in good condition, no scoring etc.
Comes with everything except pistons.
$100 ONO – NO REASONABLE OFFER REFUSED!
R32 GTS4 Manual Gearbox
Reasonable condition.
Comes complete with transfer case
2nd gear has usual R32 uneasiness to shift into when cold only.
4th gear had a little bit of a crunch when shifting into at high RPM, otherwise fine in normal conditions
$400 ONO
R32 5 Point Roll Cage
Alloy.
Great fit.
Very light
Painted black
$300 ONO
R32 4door aftermarket (fibreglass) rear bar
Unpainted.
Small chip on corner edge near wheel arch.
$200 ONO
R34 Front Cradle + Rack
Very Good condition
Offers
R32 Motorised Lower Lip
Motorised lip that lowers above a certin speed.
Or you can lock it down to make your car look more low, and raise it when need be, driveway, speed bump etc.
Comes with everything you need, motors, lip etc.
Offers - NEEDS TO GO!
HKS Style SSQ BOV
In Fully hektic chrome.
$50 ONO
GTR Fuel Pump
Comes complete with sender and everything. Bolt in job
$75 ONO
GTR R32 Intercooler
Slight damage to a couple of fins
No leaks
Will hold boost no probs
No restriction to airflow
Offers - MUST GO!!!
R33 Airbox
Complete
RB25DET
$200 ONO
GTR R32 front drive shaft - From transfer case to front diff
x2
Worked fine
$50 ONO
Stock GTST Fuel pump
Complete.
Worked fine.
Direct bolt in.
With sender
$20 ONO
Stock Turbo exhaust manifold
$20
Clutch Fan with clutch coupling and R32 fan
Worked fine
$80 ONO
Air Conditioning Compressor
Worked fine
$80 ONO
Space Saver Wheel
Heaps of tread
Un used.
Brand spankers
ANY offer
Alternator
Perfect working condition
$50
Attessa pump
Worked fine.
$50 ONO
R32 GTST/GTS4 fuel tank
+ Tank straps
Been slightly pushed in but NO LEAKS
$20 or a case of beer. - Preferably not a $20 case of beer :blush:
I'm interested in the space saver wheel.... I'll give you $50 for it plus postage.
PM me if you're interested.
Hey Cris
I might ring you about this tomorrow, but do you have your old GTS4 4wd tailshaft? As I assume your running a rwd tailshaft now? I am in dire need of one.
thanks
  • 3 weeks later...
hey there i was woundering if u hav any pics of the R32 Motorised Lower Lip at all and how much would it b to post it to adelaide
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
