Hey Guys,
I'm new to Skylines Aus. as I searched the net for a possible answer for my problem.
My R33 seems to be misfiring when its under load or around 3 quarter boost to full boost. I can only feather the accelerator as when I give it a boot full, it kicks and splutters and backfires.
If anyone else has had this problem, please comment as I miss my beast goin hard!!! lol
Cheers
https://www.sau.com.au/forums/topic/344254-help-r33-misfiring/
Could be a number of things, but this heat recently wont be helping.
Id check coil packs as a priority, then maybe spark plugs. You said R33 S2, so you dont have a separate ignitor module if im correct?? If im wrong, ignitor module would be a good place to look also.
The only other thing would be what octane fuel are you running it on??
Unrelated question....you wouldnt happen to live around St Clair (NSW) & drive a white R33 S2 would you??
the only reason you would need to regap plugs to .8 is if the coilpacks are tired, if your coilpacks are fine you run standard gap.
if you have the original coilpacks, i suggest taping them up, or buying some new ones, factory coilpacks get tired beyond 100,000km
i was having the same issues, i changed to splitfires, problem solved
Some people gap there plugs (including myself) to .8 on higher than standard boost. This is why i asked what boost he was running. On higher than standard boost engines, the more boost pressure tends to blow out the spark because of the gap being too big making the spark jump all over the place. (Hence why its breaking down). A little trick Denzo told me about a while ago.
Coilpacks maybe another fault. Its a trial and error problem.
Thanks lads.
I'm running only 7psi of boost I've never adjusted it, but i will be sure to check out the coil packs at night, it should look like a circus under the hood with the cover off if the sparks leaking!!
And for the first comment, nah sorry i'm in Batlow near Wagga Wagga, drivin a gold repsray R33 with a JUN body kit, black hood and side mirrors, aftermarket front mount, stock turbo with a HKS BOV and an Xforce 3 1/2 inch exhaust. And HRS Pegasus Black rims, 19s.
Got 130,000 clicks on the odo, but I bought it with 115,000.
Will post a pik soon
Ah cool man. Its funny cos theres a local guy here who is on green P plates & drives a white S2 R33, it was misfiring like all business the other day when he went past....good luck with it man. My money would be on coil packs for sure by the sound of things....
Cant wait for a pic :D
if they're only breaking down under load, then this wont work. having the vehicle stationary and revving it in neutral wont create any boost, and therefore no load, and the the spark will probably get through just fine. if you do manage to get the light show with no load on the engine then yeah the coil is well and totally had it
Cant wait for a pic >_<
Haha unfortunate, but now I don't feel so bad :(
Any idea where I can get some decent coil packs for a decent price?? Splitfire's if possible.
I had a look on Just Jap (which is a sweet site if you donit already know about it (www.justjap.com) and splitfires are around $650 but if thats wat it takes to get my car running perfect well then I'll just have to break the piggy bank once again. I hate ebay by the way, ya really don;t know what your getting sometimes :laugh:
Haha unfortunate, but now I don't feel so bad :P
I had a look on Just Jap (which is a sweet site if you donit already know about it (www.justjap.com) and splitfires are around $650 but if thats wat it takes to get my car running perfect well then I'll just have to break the piggy bank once again. I hate ebay by the way, ya really don;t know what your getting sometimes :ermm:
Nengun.com
I think they are around 450ish or something.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
