I have couple of brand new custom catch cans forsale, they look exactly like the cusco ones, except the inlet/outlet are on top. They come with hoses, brackets ect.
There are 2 sizes a. 80mm x 160mm
b. 60mm x 160mm
a- $160
b- $140
They are very similar to the cusco ones(pics on post #10)
product_information.asp?number=CUS-315009&variation=&aitem=9&mitem=18&back=yes&dept=876
https://www.sau.com.au/forums/topic/34430-fs-cusco-copy-oil-catch-cans/
I think, being copies and all... It's not really sufficient to link to pictures of genuine items...
Is it possible to take photos of your copies? ;)
I'm just trying to give people a general idea of what it looks like. I don't have a digital camera but i'll try to borrow one and post pics asap.
Guest RedLineGTR
People he stated in his first post that
I don't have any pics but they are very similar to the cusco ones
its called a example and he is stating that they look very similar and he states that he dosent have any pics atm which is a loss to him since people arnt that keen, so read it once or twice whatever works for you & everyone stop posting the exact same thing as the person before them has. He will try post pics up asap as he stated now.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
