My air flow meters need replacing. I ordered some replacements which arrived this morning.
My current AFM's on my R33 GTR have a orange label with the number 22680 05U00 A36-000 J70
The ones I received were stock from a R32 GTR. It has a brown label with the same model number.
My current orange labelled AFM's have 5 pin outs, but the brown labelled AFM's only have 4 pin outs.
I plugged the brown labelled AFM's in and black smoke started belching out the back when I started her up. So I guess the 5th pinout was important.
Is there a way to rewire the connection to the AFM to only use 4 pins or do I really need all 5 pins connected?
Any other suggestions?
Edited by Owens
https://www.sau.com.au/forums/topic/344571-afm-dilemma/
it sounds like you have Z32s or nismo's AFMS and you've ordered stockers
so it wont work and it would be very angry, please be careful you dont fry your new AFMs
post up pics of both please
are they both 65mm?
https://www.sau.com.au/forums/topic/344571-afm-dilemma/#findComment-5553595
I'll try and get some pictures up soon. It's currently sitting at the mechanic atm.
I took the sleeve off the plug, and there isn't a 5th wire, so that little mystery is solved.
It just doesn't make sense when both sets are the same model J70.
The only difference on the label I noticed was my old ones had JECS in big bold letters, where as the ones I received just say "jecs corporation".
Is that how you could tell if they're Z32 or not?
https://www.sau.com.au/forums/topic/344571-afm-dilemma/#findComment-5553614
measure them is the best way
but do you have std intake piping and a std ECU or aftermarket intake ducting and standalone / aftermarket ECU?
ie if you have aftermarket pod or ducting kit and standalone ECU you might have Z32s which are 80mm
if you have std piping and std ECU then you have std GTR afms which are 65mm
so physical size and look are ways to work out what ones you have
https://www.sau.com.au/forums/topic/344571-afm-dilemma/#findComment-5553742
Ecu is standard, intakes are standard, pods are after market, but had standard airbox on before.
I believe both sets of AFM's are 65mm as I had no problem bolting and fitting either of them on. Both AFM's are physically the same size.
How do you go about measuring them. I'm good with a multimeter but that's about it.
Edited by Owens
https://www.sau.com.au/forums/topic/344571-afm-dilemma/#findComment-5553748
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
