Car: 1999 R34 Black GT-T 2 door coupe
Kilometers: see below
Condition: Excellent
Reason for selling: moving interstate
Price and price conditions: $19000 ONO
Contact: PM or call 0407759650
Extra Info:
Up for sale is my much loved GT-T! Breaks my heart to sell alas she must go.
The car itself is in very good condition, always been maintained and not drive much in the last year or so. The odo says 30 something thousand I think, I'm pretty sure it's been reset at some stage in its life, the real indication is more like 80k or so IMO. Feel free to come and have a look, I'm not hiding anything - as with most imports trusting the odo reading is foolish.
HKS Fcon V-Pro computer
HKS GT-2535 Turbo
Blitz front mount intercooler
HKS coilovers
HKS EVC-5 dual stage boost controller
Walbro 255 fuel pump with direct power
Splitfire coilpacks
3" stainless dump/front pipe
Hollowed cat
Fujitsobo cat back exhaust (two big mufflers, deep note not too loud and no drone)
18" Volk F-winning zero wheels (9.5" wide rear, not sure about the front)
GTR blow off valve
Apexi turbo timer
Factory Xenon headlights + optioned driving lights
Optima yellow top battery + some jap grounding system wiring
$19000 ONO. Will trade for late model tray back ute (no fords or holdens) + cash my way. Give me a call on <removed> or send me a pm if interested!
https://www.sau.com.au/forums/topic/345022-r34-gt-t/
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
