I've got a CA S13 mainly used for track duty and I was considering grabbing a plumback BOV as it falls off boost noticeably between gear changes.
Has anyone used these bosch bovs? Any idea on what boost they'll hold? I don't need anything fancy,
http://cgi.ebay.com.au/BOV-Bosch-plus-2-5-...1#ht_500wt_1156
Furthermore, will it make a difference in reducing the amount of compressor surge which is what I assume is causing the boost to drop off so noticeably. I'm not "that" slow on the shifts.
https://www.sau.com.au/forums/topic/345116-anyone-used-these-bosch-bovs/
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
