Hey guyz iam selling my loved r32 gtr, as iam looking to update to a new car.... its a 1989 first of the gtr model in white, i have spent alot of time and money on this well maintained car, iam the first owner in
australia have had the car for last 6 years which has never given me any problems..... Its a full rebuilt rb26 with r33 gtr block,
+.040" CP FORGED PISTONS, DUDGEON PINS AND RINGS
NEW NISSAN WATER PUMP
GATES KEVLAR TIMING BELT AND BEARINGS
GENUINE NISSAN GASKET SET
JAPANESE COMPETITION BIG END AND MAIN BEARINGS
TOMEI METAL HEAD GASKET
SET OF HEAVY DUTY ARP ROD BOLTS
STANDARD INJECTORS
STANDARD TURBOS WITH STEEL COMPRESSOR WHEELS AND 360 DEGREE THRUST BEARINGS
TRUST INTERCOOLER
STANDARD AIRFLOW METERS
CUSTOM HI TECH COMPUTER
KAKIMOTO RACING GT EXHAUST
HKS TRIPPLE PLATE CLUTCH
Car also has a 6 point roll cage padded, racing drivers bucket seat, defi gauges ( oil temp, water temp, oil pressure, boost gauge) car has 9000ks since rebuilt, comes with 7inch dvd player
car is close to 300rwkw and runs very smooth.... car comes with 8 months reg..... it gets hardly driven spent alot of $$$$ on the car....
iam open to swaps depending, but more of a cash sale.... cheers any question let me know............
PRICE $22,000 ONO i want a quick sale not stupid offers or time wasters thnks...... rocky 0466883212
https://www.sau.com.au/forums/topic/345319-gtr-32-1989/
hey are you interested in swaps for a evo 3? check out the link...
http://www.carsales.com.au/all-cars/privat...5&__Dx=mode matchany&__D=gsr&silo=1011&seot=1&__sid=12C92BF03632&__N=1216 1246 1247 1252 1282 899&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pC
ar_Model_String|0&__Qpb=true&__Ntx=mode matchallpartial&Cr=0&__Ntt=gsr&trecs=2
https://www.sau.com.au/forums/topic/345319-gtr-32-1989/#findComment-5577074
Nice car dude, hopefully you still have this after xmas wouldnt mind having this one and turning my gtr into a track car, just have a few things pending at the moment, but if you still have in a couple months ill be in touch
Good luck with the sale
https://www.sau.com.au/forums/topic/345319-gtr-32-1989/#findComment-5577324
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
