Hi Mate,
Ive got the standard r32 gtr front lip in matt black,
You can have it for $170.
If your interested its in sydney
Cheers
Garth
hey i'm looking for a GT-R front lip to attach to my Gts's stock front bar, also is this possible? i noticed a few bolts coming from under and assumed it is.
cheers
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
