now this turbo cost me nearly 3k and the manifold cost me 1200, so this setup is worth over 4grand and will make easy 800hp at the wheels on your gtr.....
i have no pistures at the moment as this is more of an eoi than a neccesary sale.
the turbo has a single entry 1.06 rear housing and has an elbow welded to the polished compressor housing easy install...
the turbo also has 300dollars worth of water and oil fittings attached..
the manifold is brand new and has never been used and the turbo was on a show car that only ever got driven on and off a trailer so no stress at all... not even seeing boost(kinda sad for a turbo like this) genuine 1000hp GARRETT QUALITY!!!!!
price is $3500 or will trade for some work meisters or other high quality gear for r32 gtr.....
NO CHEAP dream boats PLEASE!!!!!!! if you are a cheap flamin mongrel then stay out of my thread....
apart from that all are welcome to throw me offers thanks
  • Like 1
  • Nope 1
  • 3 weeks later...
Anyone looking please refer to here: http://www.skylinesaustralia.com/forums/topic/346507-gtr-parts-and-tough-good-offsett-wheels/page__p__5602251#entry5602251
There may well be a reason for the delays I am experiencing, and I will happily have my posts deleted the day that I have my money or PFC, but I have made several attempts to contact Chris re this to no avail.
  • 3 weeks later...
Seller has been in touch re the item purchased from another topic, the problem appears to lie with TNT and not RB26DEBT in any way, but I am expecting delivery within a few days..
  • 5 months later...
STILL FORSALE DUE TO TIME WASTERS AND DREAMERS....
if you want a serious turbo setup fort your gtr that WILL GET YOU INTO THE 10 SECOND BRACKET AND PROBABLY THE 9 SECOND TIMEZONE IF YOU CAN DRIVE AND YOUR CAR DOESNT BRAKE.....
BUY THIS SETUP....
$2500 for the manifold and the turbo....... thats as cheap as you will ever find something like this
sorry i forgot to mention that it has a CUSTOM made rear housing..... it is a single entry T04 housing and IS an A/R 1.14.... VERRY QUICK SPOOL FOR A T51R
i am now very much over people telling me that they want to buy this and getting me to send pictures and spending my money calling them only to never hear back again...
like i said earlier i dont want to sound arrogant or rude but if your not GENUINELY interested ie: actually have money and want to buy a turbo setup...... DONT MESSAGE ME!!!!
having said that, i will sell the turbo and manifold for $2000 as a pair this weekend only!!!! if it isnt gone by monday the price will go back to normal and i will just wait till it sells... this offer is only valid for people who have not already contacted me and waisted my time
so come and buy it
  • 3 weeks later...
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
