Missfire.. Assumption
Well i have been doing some testing.
Currently got a slight modded R33 (read below) still running the cooler and turbo. After reading a Zoom magazine article where 0.9 spark plug gap was the best performer, much better than 0.6 that they tested as well.
Anyway, pulled my plugs out and they were gapped too 0.66 (after last dyno breakdown we closed the gap), and bumped it upto 0.9. Immediately it didnt have that idle miss, but underload down low it started missing (3000-4000) , but was very strong up top 5000+, where it didnt miss a beat. Mind you im pushing nearly 13psi too. Hmmm, so i think it is getting a little too much fuel midrange, maybe i should lean it off with my SAFC. So i dropped the boost back to around 12psi and now no miss. Also, with around 13psi im getting some pinging.
So my assumptions are:
1) If your running hi boost, close the gap, or lean it off, or retard the timing
2) Mild boost should be fine, with a larger gap, say 0.9
Now, im just about to put a Front Mount on, hopefully this is going to fix a few areas of heat
https://www.sau.com.au/forums/topic/34660-missfire-assumption/
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
