hey guys, a silly question but need help. Thinkin of going a 3L bottom end and have a spare r33 gts4 gearbox. Form what i can gather they are the same strenght as a GTR box but different ratio. Now my question is, can i use it on a RB30 and what tailshaft/diff would i need ? Or just stick with the normal gtst box ?
Any help is appreciated
https://www.sau.com.au/forums/topic/346728-r33-gts4/
What car? I'm assuming is a RWD platform as you talk about re-using your gtst gearbox...
If it's an R32 GTSt, I killed my stock box very quickly after chucking the 3L in.
If it's an R33 GTSt, then your box is already as strong as a GTR box as they are pretty much the same internals (I upgraded to an RB25DET box, including the box and custom tailshaft good for 800Nm, and some other bits like slave cylinders, pivot ball etc, cost me nearly $2.5k and I did the work myself).
Using a 4WD gearbox in a RWD application requires some cutting and shutting.. easier to use an R33 RB25DET box.
https://www.sau.com.au/forums/topic/346728-r33-gts4/#findComment-5584951
will be rwd 33 and i have a spare gts4 which im stripping. need to know if i should keep the gbox or sell it. dont have a 33gtst box though. i would just use that...like u said.
https://www.sau.com.au/forums/topic/346728-r33-gts4/#findComment-5585097
the trouble there is r33 gts4's are pretty rare, and the demand for that gbox wouldn't be strong. even gtr boxes are cheap as chips so i wouldnt expect much for that one. it probably isn't expensive to have the transfer case removed and sealed off so i'd seriously look at that, given that its got the same internals as the 2wd turbo box anyway so you'd have a good gearbox for little expense.
https://www.sau.com.au/forums/topic/346728-r33-gts4/#findComment-5602729
  • 1 year later...
I have a stock R33 gtst gear box, Will strip it out for the right price. pm me if your intrested mate-
No one has ever confirmed the stenght of internals - Im planning to run 300+ kw through mine- Been N/A up untill now.
A few people on here have put plenty of poke through them with no worries, depends how you treat it though- 8k dumps and smashing gears isent goign to be good for any stock box.
https://www.sau.com.au/forums/topic/346728-r33-gts4/#findComment-6506817
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
