pics:http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=170577348520&ssPageName=STRK:MESELX:IT
forged motor rb25det after maket everything built to drift done less then 50kms since build as hasnt been on road. had run in tune at daltons automotive in geelong
trans-manual rb25 box
forged bottom end rb25(just had run in tune)
adjustable cam gear
nismo 555cc injectors
bosch 044 fuel pump (not installed but brand new)
garret 25/40 turbo
z32 afm
cusco os clutch an cermic fly wheel
after market dump pipe and full exhuast
r33 brake upgrade and 5 stud convo
coilover fully adjustable front an rear
fmic
hks oil cooler 12 row
uras body kit
light wieght racing rims 2 brand new rear tyres $500 each r33 stockies painted black
defi infomation computer with heads up display
k series gauge's oil temp,oil pressure,water temp
defi boost gauge
mircotech lt10
hks boost controller
hks turbo timer
bride bucket seat and racing harness
after market steering wheel
blitz bov aftermarket
diff hicas lockbar
thats all i can think off at this time (motor cost 4.5k alone)
car must sell i am started my own business and need the money or swap for ute would like a dualcab with cash my WAY this car has alot of money spend on it an was built to run 300kw all day everyday<br style="font-family: Arial Black;">never had time or money to finish as to haven childen an new house<br style="font-family: Arial Black;">feel free to ring me 0401492031
https://www.sau.com.au/forums/topic/347063-cefiro-7500/
yea man got dyno sheet somewhere it ran 126kw on 5psi and was shut off at 5000rpm as its just run in tune. it was hopeing to make around 270-280rwkw with full tune should shit that it on a safe tune
Edited by ceffydrifter
https://www.sau.com.au/forums/topic/347063-cefiro-7500/#findComment-5587344
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
