Hey guys up for sale is an ARC intercooler core for r32/33 GTR
600x300x75mm
3"inlet/outlet
Good condition few bent fins on front but not much and there's a few on the back but that's the back. Reason for sale is because I was going to install on gtst but need to get custom piping and brackets so couldn't be bothered going ahead with it. It does NOT have the ARC painted on the fins
$300
willing to post
Edited by R32IST
https://www.sau.com.au/forums/topic/347576-bnr32-arc-intercooler/
