[Act] Fs: Mint Caparison Angelus Hgs Pro Black Gsm $1500 Ono
Hey guys and girls, I've gotta sell one of my electric guitars to make way for other financial commitments. I suspected this might happen in advance, therefore it's had very little play (to keep it in mint condition). It's a Caparison Angelus, all I've done is chuck some slightly heavier gauge strings on (11.5 16 26 36 46 60). The strings they put on it when they ship are ridiculously light for something meant to tune to B standard. (It holds any tuning just fine if you use the appropriate strings).
It comes in the standard Caparison hard case. I'm in the ACT but would be willing to ship within Australia. Obviously a local sale would be preferable. If I have to ship it, I'll slack the strings off, and I still have the double box used to ship it to me from Japan originally, so it'll be packed insanely well.
I'm looking for $1500 Or Near Offer (which will include shipping within AU). I paid $2200 for it from a shop a coupla months ago, so bare this in mind if you like to 'haggle'.
These are the same guitars used by the Swedish metal band Soilwork (my heroes!). It's the same kind of model that Peter Wichers uses on the "Young Guitar" demonstrations (you can find this on youtube). All he did was chuck an EMG81 in it (but the stock pickups sound insanely beefy to me). I will be sorry to see this go :(
Here are the specs:
Body Material: Mahogany Back w/ Arched Maple Top
Neck Material: Hard Maple
Fretboard: Ebony
Neck Joint: Set Neck
Scale Length: 24.75"
No. Frets: 24
Headstock: Angelus
Headstock Angle: 15°
Machine Heads: Gotoh SG381-07 H.A.P.
Bridge: Gotoh GE103 B-T, Gotoh GE101 Z-T Tailpiece
Nut: Graph Tech Trem Nut
Hardware Color: Schaller-Black, Gotoh-Cosmo Black
Pickups: Neck - Caparison PH-F
Bridge - Caparison PH-R
Controls" Neck Pickup Volume(CTS), Bridge Pickup Volume(CTS), 3 Way Lever Switch
Case: Hard Case Included
Welcome anyone who wants to come and try it out.
Here are some pics:
Feel free to ask any questions: you are MUCH better ringing, rather than sending a PM: 0404 896 713.
Ben.
Edited by sl33py
  • 10 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
