http://www.motorauthority.com/blog/1052749_nissan-gt-r-driver-suffers-fatal-crash
Car looks pretty rough, must have been a bad one.
We’ve reported on plenty of supercar crashes in the past but apart from a few egos, and possibly wallets, being hurt, everyone is generally okay in the end.
This time we’re sad to report that a 31-year old German man suffered a fatal crash in a Nissan GT-R while going around a dangerous curve in the Eppan region of Italy. Another 14 people in the bus he collided with were also injured, with everything from small cuts and abrasions to cervical trauma being reported.
From the amount of damage inflicted on the front-end of his dark grey GT-R it’s safe to assume the driver must have been traveling at some speed when the accident occurred. It took rescuers hours to free the driver from the mangled mess but he was already dead by the time they got to him.
Stories like this once again highlight the important fact that high-speed driving should be reserved for track days only and not public roads, no matter your skill level--real or perceived--behind the wheel.
https://www.sau.com.au/forums/topic/348227-gt-r-driver-dies-injures-14-others/
Aren't we assuming that the GT-R driver is solely at fault?
I can't see where it says the bus driver isn't at fault?
Both could have been speeding eh what?
Or perhaps the bus driver was on 'speed'?
Have you ever wondered when you're driving your 'Line, that if some idiot ran into you, you'd be the one who's wrongly presumed at fault? I have! >_<
Have you ever wondered when you're driving your 'Line, that if some idiot ran into you, you'd be the one who's wrongly presumed at fault? I have! pinch.gif
I don't think the bus driver is at fault. If the bus driver is at fault, there will be lots of witnesses on the bus that will say how the bus was driven.
Maybe the GTR driver fell asleep, or drunk behind the wheels?
Edited by Victor.T
By the time it was reported VT, it's all heresay.
The only people that know will be the GT-R driver, the bus driver and the person in the jumpseat > and one of those is dead.
Who's in the jumpseat?? :P
Anyhow, the point is, if GTR driver crashed it like the news said (Over speed, etc.), he deserved it.
But if it was the bus driver's fault (Or just an accident, like insufficient road lighting, etc.) and the other car involved was a high-performance car (People started jumping into this band wagon of Fast car = Hoon), then the news is S**t.
Either way, 1 good car off the face of the earth. :(
Considering he's hit a bus which is basically has a chassis built like a battering ram its no wonder the car looks so stuffed. Even if the two vehicles were doing 80km/h, the kinetic energy of a frontal colision is going to make the gtr look very 2nd hand. He may as well have hit a concrete wall at 160. Same kind of effect.
The accident happened on a curved road so who is to say the bus wasnt on the wrong side of the road. I frequently drive a near by range and trucks and long vehicles are always crossing double lines torward oncoming traffic around blind corners. The do this so their trailers/rear wheels don't fall off the road at the apex of the corners. Still knowing this happens doesnt stop you from occasionally having near misses, and accidents happen quite frequently. They have lowered the speed limit to 60km/h now to reduce the number of fatality incidents.
Im with Terry on this one. A mate was driving along at the speed limit in an import in townsville a few years back. He passed through an intersection that had a green signal, and was t-boned by an ambulance that ran a red signal. When emergency services arrived and the cops they interrigated him and tried to get him to take the blame for causing the accident while he was still in shock, and before offering medical assistance.
This would be the brotherhood of public servants watching each others backs, and trying to get the driver of an import to take the blame for doing absolutely nothing wrong. Fortunatly his mother was in the car and was a witness to the fact he wasnt speeding, and did indeed have a green traffic signal.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
