It doesn't have to be on the 20th/21st Ska
Both me and MJ are cool for any Sunday, I just want to make it worth Spectrix's time to do this.
Lets just wait and see who else bites first before we commit to times and dates ;)
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715324
  • Replies 168
Hey cam.
Your cars still off the road hey.
I hadn't forgotten about you dude. By the time you have the GTR running I might have found some Brembo stencils for your calipers.  ;)
Hey mate,
Yeah still off the road, although things might be looking up as I am picking up the turbos this arvo & have got all new hoses from my brother who works at Westpoint Nissan & are picking those up this arvo too.... so shouldn't be too long away now...
Cam
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715449
Hey mate,
Cam
Excellent news cam. You up for a trip down the coast? ;)
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715457
Gets towed there tommorrow, and they said it was all booked out this week, but may be able to squeeze it in, you know how good they are, so I would not expect it this week, hopefully fingers crossed, next week, oh also found a cheap tow truck dude who comes highly reckomended, so once he takes it there see how good he is and post his number so that all can use a good cheap tow truck.
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715585
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
