I posted a topic a few weeks ago about this problem but didn't get anywhere so I'm here again with some updates.
The problem is that my car developed a hesitation while cruising. No engine lights came on the first few times however after a while the SLIP light would come on & stay on (TCS turned off). Lately at times the engine light will also come on with the SLIP light.
Took it to a workshop who ran the ecu error codes and came up with the code for the AFM so I bought a brand new generic one and still have the same problem.
It's slowly getting worse & worse with it having a extremely tough idle on start up this morning then cutting out completely.
Ideas?
https://www.sau.com.au/forums/topic/348616-r34-hesitation-cut-out-on-start-up/
Engine light + SLIP is typically caused by busted coil packs. Next time they light up have a look at the ECU fault codes - the paperclip method is easy to follow. If you get 21 (ignition signal) it's 99% certain it's the coil packs. 50-60k they should still be good but you never know.
Here's a list of other things you can try: Resolved Misfire In R34 Gtt - Rb25det Neo Checklist and links to other misfire threads. Good luck.
Maybe it's as simple as a bad connection on the AFM plug. Or a faulty bit of wiring somewhere.
Some contact cleaner (or even WD40 works) sprayed inside both sides of the connection should make sure it's getting a nice clean electrical connection.
Good luck
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
