Hi all,
I've got pair of Recaro SR3 seats with rails to suit R32-R34 Skylines (except for R34 GT-t), they're red in colour, could use a good clean as there is some marks and cigarette hole.
Asking $1200 ONO.
Pair of Genuine Recaro Rails to suit R32-R34 Skylines (except for R34 GT-t).
Asking $250 ONO.
Pair of Noltec Castor rod, brand new (not in box though been sitting under my desk for a while).
Asking $200 ONO.
Retrimmed R32 GTR rear seats in grey with orange inserts.
FREE pick up only.
Pair of HKS adjustable actuators, these are preloaded at 14psi and can be adjusted to 22psi (this is how high I've ran on my old GTR).
Asking $200 ONO.
I have 2x R32/R33 GTR front pipes.
FREE pick up only.
Items are located at Doncaster East, VIC. May post smaller items.
Contact me through PM or text me on 0430 129 511.
Cheers
Grant
hey keen on pics of the seats and if they arnt what i am after the rails to suit recaros :)
Thanks
Text me and I shall mms you with pics I've got on my phone.
Cheers
Grant
Yo peoples,
There are some pictures of Recaro Seats.
Other bits, I haven't taken some yet.
Reasonable offers are welcome, worse I can say is no, would like to clear these bits out.
Cheers
Grant
Geez it's bumpy there...
If these Recaros seems to be bit too dear for you, make me an offer.
Or I've got standard R32 GTR seats I might get rid of, passenger seats are in good condition bar a cigarette burn, drivers side have small tear on RHS bolster and RHS side had retrim at one stage. Asking $400 pair or best offer. Pics to come.
Also offers are welcomed on these parts I've got to sell.
Cheers
Grant
Still have them minus HKS Actuators and maybe Standard Seats.
Do feel free to make an offer for them.
Cheers
Grant
Hi all,
Bumping this thread.
Just to make it clear, HKS actuators are SOLD somehow I didn't update this thread (had other thread that I advertise this part).
Recaro SR3 are sold as well.
Everything else still available, don't be afraid to make me an offer.
Cheers
Grant
Hi all,
Asking $200 ONO.
Asking $150 ONO.
FREE pick up only.
FREE pick up only.
Cheers
Grant
Price drop on some items, but do feel free to make a offer on some parts.
Too bad you didn't snap them up sooner.
Castor rods, rear seats, front pipe still up for grabs.
Also have Garage Saurus remapped ecu for R33 GTR - tune for 14psi, pod filters and exhaust, have usual rev limiter and speed limiter removed. $50.
Cheers
Grant
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
