1998 Nissan Skyline R34 Silver Coupe P-PLATE LEGAL
SEMI-AUTO
car has done genuine 89000kms
Has been serviced every 5000kms
REG till end of march 2011 and roadworthy.
EXTERIOR
-Stock 16inch rims with 80% tread on front and rear
-XENON 6000k headlights with m-tek LED parkers
-Custom made cat-back exhaust sytem with Drift titanium tip 3inch cannon
Stock exhaust system can be supplied if requested.
-Silver paint is like brand new.
INTERIOR
-Drift OIL TEMP GAUGE
-DRIFT OIL PRESSURE GAUGE
-DRIFT BATTERY VOLTAGE GAUGE
in a 3 gauge pod.
SEATS ARE PERFECT, no rips, stains or marks.
CARPET has no tears, no rips, no stains
CLARION CD PLAYER AND CLARIO SPEAKERS.
Car has been looked after and washed and detailed every week.
https://www.sau.com.au/forums/topic/348689-r34-skyline-coupe-non-turbo-13500/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
