hi guys,
i am interested in this gtr but i query why only the engine bay was resprayed & not the outside of the car, the seller also explained that it was in a front end hit but not sure of the extent of damage as he bought it after it was repaired...anyway, i cross checked the 'strut tower' where it meets with the 'wheel arch' on my current gtr & it is definitely a smooth finish with a hard film of silastic to finish it off(it looks factory)...whereas these pics look like it has been welded & looks quite messy - what are your thoughts guys?
this looks messy as well, passenger side bonnet hinge mount to body:
i'd hate to buy a car then find out later that it may have been a cut & shut :(
something else i spotted is that the front right guard sits higher than the door...hmmm
please let me know what you think - thanks in advance
https://www.sau.com.au/forums/topic/349132-does-this-look-odd/
are u referring to the underside where the weld cannot be seen? i'd have to get the wheel off & black plastic inner wheel arch cover.
what doesnt make sense is why would the spray painter make a new seam when the factory finish looks great & his finish looks terrible? my only explanation is that the front end hit must have been hard enough to squash the front wheel arches & new have newly fitted wheel arch guards
thanks anthony, but why would you ruin a nice factory seal with aftermarket sealer? what is underneath? is it hiding something underneath like a major repair?
do you think that the wheel arches have been changed due to a big front end accident? to dmamage the wheel arches chances are that it may have structural damage...
i just spoke to my panel beater who is highly reputable here in sydney & he said to stay clear.
his rule of thumb "if it doesnt look like the factory seal or 1 side looks different to the other side, they're hiding something"
in this case both sides look the same so both sides have been done with new wheel arch skirts
...makes sense to me :)
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
