  • 4 weeks later...
Item Summary: TOYOTA SPRINTER,
Postcode: 7315
Odometre: 0 kilometres
Asking Price: $7,500 price drop $6500
Condition: Used
Reason for Selling: need money
Delivery Methods: PickUp
Contact Info: 0400622682
Extra Information:
Specs:
Year: 1983
Make: Toyota
Model: sprinter ae86
Engine Bay:
4age (recently rebuilt 3k worth) runs awesome
Pod filter
Thermo fan
Exhaust (sounds awesome)
Suspension/Wheels/Tyres:
Adjustable high and camber coilovers in front
Stiff springs in the rear
Longchamp rims 15x7in +11 (I think that is the right with and offset from)
Good tread on all tires
Drive train: standard Gear box, and dif and brakes but they are all good!!
Exterior:
no rust and straight as!!!!
After market Side skirts and front lip
Paint has faded on roof and boot but other than that the paint is in good nick.
Interior:
beep dish steering wheel
Oil pressure gauge
Engine temp gauge
The interior is extremely neat!
Extra parts that come with it:
Fibber glass front and rear bumper
Full diff (welded)
6 mashies/stellies, a few bald ones but some have a heap of tread.
And a box off goodies.
Open for swap with cash adjustment either way (s13, 180sx, r32 etc)
Rego to the 6th 2011, Over all the car is in awesome condition, goes awesome and handles awesome!!!
located in Ulverstone. 0400622682
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
