hi everyone
up for sale is my s14 s1 200sx 1996
it has a neo rb25engine in it with the following mods
KKR 480 turbo runing 9 psi
front mount intercooler
dual core alloy radiator
twin 12 inch thermos
rebuilt rb20 gearbox (hasent missed a beat)
brand new thermostat and water pump
new exedy race clutch with machined flywheel
shimmed diff with 4.3 ratio gears (really tight)
3inch exhaust done by exhaust technology
solid gearbox and cradle bushes
lowered king springs
brand new battery
pioneer cd player
17 inch rims
and a few other things
the car drives really well has no flaws and is a regretful sale and its not engineered with that engine
its a strange colour it looks purple in the sun blue in tha shade and green in other light
im asking $12500 ono
any questions u can ring me on 0408494856
https://www.sau.com.au/forums/topic/349947-neo-rb25-s14/
  • 3 months later...
