Cusco zero 2E coilovers
suit r32
8/6 spring rate.
dont less than 5000 km. pretty much brand new.
2 way height adjustable
$1400
postage 30-60 bucks oz wide
Cusco zero 2R rear coilovers
suit r34 gtt, r34 gtr, r33 gtr, r32 gtr
mint contition, barely been used at all. like new
6 way damper adjustable (might be 5, ill check though)
6kg spring rate.
$700
Cusco caster rods
suit r32, s13, a31, 180 ect
suit gtr's with spacer on 1 side
perfect working order.
$220
rb25 manifold
came with a car i bought, its off an rb25. i have no use for it.
$150
mackie
0422 905 956
Edited by flame_this
https://www.sau.com.au/forums/topic/351089-cusco-coilovers-basically-new/
the top set of coilovers is for r32 gtst models.
happy to mix the sets if a set of coilovers is required for r34/ gtr, r32 gts4 or any other models.
best just to pm or contact me on the number though.
cheers
R33 rears go nowhere near fitting R32s, that pair of rears will be about 6 inches too long for R32, you can see it from the photos... I had to give away a shit hot set of Bilsteins for exactly that reason
yeah... there a completely different coilover, didnt imply nething here suited r33 other than the r33GTR rear coilovers there which suit r34 gtt and r34 GTR models.
have an r33 set in a different set if anyones interested.
the r32 cusco zero 2 E's are sold pending payment.
r34 GTT, r33/r34 GTR rear cusco still available.
  • 11 months later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
