old setup,
fmic, safc, exh, small t3 highflow, pod= 192rwkw@1bar
will have the new setup finnished soon with td06, gtr injectors, bigger pump, ecu. (std manifold/plenum/tb/coils etc) anyone had problems with the std coil packs at higher power levels? i was forced to run a really small gap on the plugs to stop it missfiring with the old setup already
  • Replies 44
Hi just wondering what you guys think. I am going to do a rebuilt in the not too distant future on my RB20DET. I wish to have the tomei 2.2ltr pistons and have the tomei 260 Duration, 8.5 mm lift cams (both inlet and exaust). Possibley a set of tomie valve springs. The only thing I need to know is what turbo would be good for this set up.
I was thinking GT2835 but I don't really know what to expect from this turbo. A set of 550cc injectors would probs be the injectors used too.
In the end I want a reliable 250 odd rwkws. Any advise would be great thanx guys.
dont know what to expect hp wise all depends on the tuner i suspose the head is of my rb20det geting ported at the moment and all the mods are going on as it is reasambled the mods are
Q45 afm
hks cam gears
hybrid 600x300x76 fmic
hks 264 cams inlet +exhaust (9.0mm)
grex remote oil filter
oil cooler
gtr fuel pump
nismo fuel regulator
recon 460 hi flowed injectors
twin thermo fans
cast hks exhaust manifold
hks 32mm external waste gate
hks panel filter with cold air induction
to4e bb turbo (new)
3" trust exhaust with hyflow cat
custom dump pipe
extreme clutch and pressure plate
master cylinder brace
wolf 3d ver 4 plugin ecu
and as i said the head has been ported and the valves are going back in next week but the bottom end is staying stock engine only has 60,000 ks on it hone marks in the bore still look like new very little wear no piston slap hp goal well lets just wait and c as i said depends how good the tuner is these parts will be going on in the next month or so as i get time to assemble it the main reason for bolt on parts only at the moment and stock bottom end is the long term goal is an rb30det as all these parts will still bolt on to it the bottom end is being done in that engine so if this one goes bang it dont matter as the other engine goes in then kinda keen to find out myself wot sorta hp it will make hoping for around the 250rwkw though
If you ran this setup (assuming motor has forged pistons), where would your new redline be now?
Meh, forget forged pistons...i dont hear about too many RB20s killing pistons, they seem to normally get tired and stop making the power they once did, so im not going to bother whilst the engine still has good even compression.
Im going to keep my rev limit between 8,00-8,500rpm depending where boost comes on with new cams and cam gears, assuming it is still making good power. Ill grab some valvesprings whilst im at it because my engine has got 170,000kms on it.
hehe 2nd time was intentional.. told them to wind in lotsa boost rofl. Not like a replacement RB20 costs anything :D
Based on your experiences then ill see you all in the graveyard shortly... :wavey:
...but seriously these engines sound as though they gave up the ghost because of youthful exuberence more then piston failure. Im sure most cars that are simply boosted up with little attention to A/F, engine fueling, cooling etc will have probs.
Anyway i put my theory to the test shortly :D
HKS GT2510 Turbo
Re-mapped stock computer
Stock injectors
Bosch 040 pump
3" exhaust
FMIC 600x300x70mm approx
Pod filter with air feed
Remote oil filter and cooler
Extreme single plate clutch with 4.5kg cromoly flywheel
Modifed stock BOV (bypass/overboost hole plugged)
200.4rwkw at 1bar with stock BOV, 200.2rwkw at 0.9bar with BOV modded)
Boost controller problems meant that the run with the modded BOV was done with no boost controller, only the HKS acutator contolling boost
I'd say 210 rwkw at 1bar with boost controller working. I have run up to 1.4 bar with octance boost, but haven't dyno'd it at that due to boost controller problem
In process of planning the next stage to try and get 220-230rwkw
Motor is stock, 125,000km and may be replaced with a fresher but still stock example when the next stage starts
he he yeah... :wavey: pistons... crack, crack, crack, crack, crack, crack, crack.
count em. all seven.
yep did both lands on no#5, and my oil rings were siezed together & my compression rings have worn down about 10thou.
I'll take better care next time 'round
Yes
just thought I'd ask for a opinion from everyone in reagrds to RB20 upgrades
After reading a thread in regards to modified RB20 power outputs, Sydneykid mentioned fitting standard RB26 cams to a RB20
from what I can gather on the thread, the cams are a straight swap?
I want to use a set, but I am unsure of wether to isnstall them as is,or convert to solid lifters as well
The motor itself, hopefully, will remain internally standard, with a rev limit of no more than 8100rpm, so I am unsure if the solid lifters would be a improvement or a advantage?
Also, I may add a set of cam gears as well if needed
My goal is 230rwkw (currently 200rwkw) at around 1.3bar of boost. I am installing GTR injectors, Microtech computer as well. All the other stuff - HKS GT2510 turbo, FMIC, fuel pump etc are already proven performers and will stay as is
Will the GTR cams help, with standard hydraulic lifters, and what type of increases have you seen in the past?
Sorry for all the questions,
regards, Chris
I should be able to give you an answer in about 2 weeks, picking up the cams and cam gears next weekend.
Cool, I look forward to seeing the results
Are you going to run them with stock lifters etc?
Are all RB26 cams the same? By looking at the specs on the Tomei site it suggestes they are, but each model the torque output seems to rise, maybe suggesting a differant camshaft profile for each model?? Are yours 32 or 33 cams?
Running std hydraulic lifters with GTR Valve springs and cams...only changing the valve springs as my engine has done 170,00kms so probably well past their best.
Good quesiton about the cam differences R32 to R33 etc. Could be the different turbos and tuning that increased the torque more then a mechanical change in the engine...i think the cams im getting are off an R32 GTR
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
